[mapserver-dev] SWF Output : Labels + Ming 0.4
Yewondwossen Assefa yassefa at dmsolutions.ca
Mon Jan 19 18:47:53 EST 2009
Thanks Laurent. I have created a bug and attached the your file to it.
If possible, can you add yourself in cc to this bug?
  http://trac.osgeo.org/mapserver/ticket/2858
Assefa
laurent.baey at free.fr wrote:
> Hi all,
> I've been working on mapswf.c to enhance label readability. I decided to
> use filters on movieClips in order to add
> - a Glowing Effect when an outline is set on the label
> - a DropShadow Effect when a shadow is set on the label
> these are not too shiny, but really enhance the map I think.
> It reduces the memory size of the map as well, as the label is not
> duplicated, but enhanced at Flash run time.
> I had to switch to Ming 0.4.1 to do so. It adds a lot of new features
> and is quite stable for now.
> Some functions where deprecated, I choose to use the new ones, so I
> think there's a little work to do in order to detect which Ming version
> is present at configure time, and then choose the old, or the new set of
> functions.
> Everything works quite well, so I give here my mapswf.c, maybe Assefa
> can take a look, add the necessary ifdefs, and if someone likes the
> effects, commit :).
> Thank you
> Laurent Baey
> This message was sent using IMP, the Internet Messaging Program.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
