[mapserver-dev] count points in polygon
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jan 19 23:24:09 EST 2009
Mathias Tobler wrote:
>   For a system showing dynamic species distributino maps I am looking
> for a way to count the number of points in each polygon of a polygon
> layer. I am using MapScript to dynamically add the points from data
> stored in MySQL. The polygon layer is a regular shapefile that can
> either be a regular grid or a shapefile of countries or regions. Due to
> the larger application this will be part of I am limited to MySQL and
> won't be able to use PostGIS or any other spatial database. I could
> probably loop through all points and polygon in MapScript and use the
> $status = $polygon->contains($point);  function, but considering that
> there can be 100'000 or more points this can get really slow. Is there
> any function that will do this?
I think I would recommend that you add a column to your points table and
then cycle through each point, determine what polygon it is in and
update the column with the polygon's uid. Then you can do a query like:
select polygon_uid, count(*) from points group by polygon_uid;
-Steve W
