[mapserver-dev] SWF Output : Labels + Ming 0.4
laurent.baey at free.fr laurent.baey at free.fr
Tue Jan 20 05:18:22 EST 2009
Thanks
I added a new version of mapswf.c with the ifdefs, which needs an
appended version of the configure script.
Aside Effects, one noticeable new feature in ming 0.4 among others is
the ability to load TrueType font files, no need to convert TTF fonts
into FDB format anymore, that means only one fontset.txt for all
mapfile outputs.
Laurent
----- Message de yassefa at dmsolutions.ca ---------
    Date : Mon, 19 Jan 2009 18:47:53 -0500
     De : Yewondwossen Assefa <yassefa at dmsolutions.ca>
Répondre à : Yewondwossen Assefa <yassefa at dmsolutions.ca>
Objet : Re: [mapserver-dev] SWF Output : Labels + Ming 0.4
      À : laurent.baey at free.fr
     Cc : mapserver-dev Mailing List
<mapserver-dev at lists.osgeo.org>
> Thanks Laurent. I have created a bug and attached the your file to
it.
> If possible, can you add yourself in cc to this bug?
>   http://trac.osgeo.org/mapserver/ticket/2858
> Assefa
> laurent.baey at free.fr wrote:
>> Hi all,
>> I've been working on mapswf.c to enhance label readability. I
>> decided to use filters on movieClips in order to add
>> - a Glowing Effect when an outline is set on the label
>> - a DropShadow Effect when a shadow is set on the label
>> these are not too shiny, but really enhance the map I think.
>> It reduces the memory size of the map as well, as the label is
not
>> duplicated, but enhanced at Flash run time.
>> I had to switch to Ming 0.4.1 to do so. It adds a lot of new
>> features and is quite stable for now.
>> Some functions where deprecated, I choose to use the new ones, so
I
>> think there's a little work to do in order to detect which Ming
>> version is present at configure time, and then choose the old,
or
>> the new set of functions.
>> Everything works quite well, so I give here my mapswf.c, maybe
>> Assefa can take a look, add the necessary ifdefs, and if someone
>> likes the effects, commit :).
>> Thank you
>> Laurent Baey
>> This message was sent using IMP, the Internet Messaging Program.
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
----- Fin du message de yassefa at dmsolutions.ca -----
