Antwort: [mapserver-dev] PDF support wrap up...
Brent Fraser bfraser at geoanalytic.com
Wed Jan 21 11:38:28 EST 2009
Benedikt,
  I've got a few questions...
umn-ms at hydrotec.de wrote:
> In some apps we create PDF with Java, XSLT an Apache/FOP.
> * Spatial and non-spatial Data in relational Database
> * Mapserver: Creates PNG-Map from Database
Do you do any labeling with Mapserver?  If so, any problems with label placement?
What is the typical size (pixels/lines) of the PNG?
> * Java: Create XML from Database
> * XSLT: Create XSL-FO from XML (links to PNG)
Is this where the Mapserver-generated PNG is integrated into the output document?
> * Apache-FOP: Create PDF from XML  (embedd PNG)
> Experience:
> + Can tweak layout
> + Map with true scale
How do you ensure the PNG is rendered to a specific scale (e.g. 1:50,000)?
Thanks!
Brent Fraser
