[mapserver-dev] rfc49: call for vote
Daniel Morissette
dmorissette at mapgears.com
Fri Jan 23 15:58:12 EST 2009
If LABELMETHOD and labelObj for layer are postponed until after 5.4 then
I think that should be made clear in the RFC (which is tagged for 5.4),
or even moved to a separate RFC, otherwise it will be very hard to
figure out what was done in which release when devs/users look back at
the RFC in a few years (Yes, I do refer to old RFCs all the time).
I'm +1 otherwise.
Daniel
thomas bonfort wrote:
> Hi devs,
> I'd like to get this in for 5.4:
> http://mapserver.org/development/rfc/ms-rfc-49.html
> wrapping up the comments from the review period, I think there isn't
> any issue preventing a vote:
> * possible values for LABELMETHOD (the default is to use cog) :
> awaiting implementation, very probably postponed to after 5.4 (unless
> Steve planned to implement this soon ?)
> * labelObj for layer: implementation postponed to after 5.4
> * fractional values also for pattern,gap, offset: a good candidate
> for 6.0 (when pattern and gap would be moved to the styleObj?)
> * there was concensus for adding parametered scaling, usefull for
> thematic mapping (eg size proportional to a feature attribute)
> - by allowing simple expressions, eg SIZE ( 18 + [poptotal] * ((
> 43-18)/(5000-30000)) )
> - or by adding pseudoitems at the layer level:
> PSEUDOITEM
> 'mySize' (mrange([itemname], mininput, maxinput, minoutput,
> maxoutput))
> 'myText (commify(round([itemname], 2)) + ' ac')
> END
> LABELITEM 'myText'
> CLASS
> STYLE
> COLOR 255 0 0
> SIZE [mySize]
> END
> LABEL
> END
> END
> this enhancement will be addressed in a specific rfc.
> best regards,
> Thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
