[mapserver-dev] Fractional label sizes (post RFC49 comments)
thomas bonfort thomas.bonfort at gmail.com
Wed Jan 28 12:42:03 EST 2009
Tamas,
I have no objection for this change
For pixmap fonts, the size will have to be MS_NINT'd so as to fall
back to one of the gd predefined constants. You might also want to
look into the label's min/max size and see if they need to be adjusted
and/or transformed to doubles also.
best regards,
thomas
On Tue, Jan 27, 2009 at 22:27, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi Folks,
> It would be reasonable to add fractional label size support as per RFC49
> before the next release. (I thought it has already been addressed by this
> RFC but unfortunately not). I guess however it wouldn't be a big deal since
> either GD or AGG use label sizes of data type double internally when
> rendering truetype labels. By adding this option I guess we could easily
> configure scale dependent labels either with the SIZEUNITS=DD settings.
> Another reason I've come up with this feature is to get better support of
> setting the label sizes for OGR and using the STYLEITEM=AUTO option and
> having the label sizes in map ground units in the mapinfo layer.
> I'd volunteer to support this change within RFC49 if no one will object to
> this.
> Best regards,
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
