[mapserver-dev] SVG symbol support-MapServer
Daniel Morissette dmorissette at mapgears.com
Tue Jul 7 14:39:29 EDT 2009
Paul Spencer wrote:
> this is probably way too late but did anyone look at the svg support in
> agg?  It says it supports only the minimum required but the previews
> make it look like it supports quite a bit?
> http://www.antigrain.com/svg/index.html
Steve Lime wrote:
> Will be there... What about rolling our own using AGG? There apparently is a relatively basic implementation
> of a SVG viewer in AGG out there. Depends on how much of the SVG spec would have to be supported to
> create symbols I guess.
Thanks guys! Sounds like we have another viable option to explore.
Daniel
Daniel Morissette
http://www.mapgears.com/
