[mapserver-dev] Technical manual (development manual, tutorial)?
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jul 13 22:59:54 EDT 2009
Gustav Allen wrote:
> Hello community
> I have experience installing and using MapServer on Windows and Linux
> plataform. But now I'm interested in contributing as a developer
> MapServer. I am interested to know: if you have technical manual
> (development manual, tutorial or whatever)   or   how do you develop?. I
> read the info in the website mapserver.org <http://mapserver.org>
> (development section), but it is insufficient =(
> Until now, I know that I need GDB + frontend (ex.
> Emacs,KDbg,DDD,Nemiver) for debugging mapserv executable on Linux.. I
> tried to debug it,but  I couldn't ( note: I have installed all the
> required libraries )..
> Always GDB detects " parsing errors in my mapfile".. But I think it is
> impossible because my mapfiles are fine.. My web applications work with
> the mapfiles. The same situation occurs with test files :
> /mapserver-5.4.1/tests/test.map ...
> Really is very frustrating. please...somebody can tell me some steps to
> develop on mapserver.... because I haven't found clear info
Gustav,
A few ideas to get you started:
1) if you plan to debug mapserv make sure you ./configure --with-debug
2) you might start debuging using shp2img
    a) start by getting shp2img to run with some command line options
    b) gdb shp2img
       break main
       run <commandline options>
3) to debug mapserv you can use
    a) gdb mapserv
       break main
       run QUERY_STRING='url-params-after?'
Try some of these and see if you get any further.
-Steve W
> Thanks a lot
> Gustav Allen
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
