[mapserver-dev] A basic question about mapserver functions
Mauricio Herrera georazor at gmail.com
Mon Jul 20 02:50:27 EDT 2009
Hello
Really I hope you  can help me with next doubt,I appreciate your help...
Well, I am drawing  a function map of mapserver. Because I would like to
know all internal structure of mapserver. However
I have a problem with DATA. I don't understand what function links  DATA
value (layer->data) with next functions:
   - imageObj *msDrawMap(mapObj *map, int querymap)
   - int msShapefileOpen(shapefileObj *shpfile, char *mode, char *filename,
   int log_failures)
(LoadLayer) file mapfile.c  <----- What is the link function for DATA value?
--------->(msDrawMap) file mapdraw.c
---------> (msShapefileOpen) file mapshape.c
For example:
1.-loadLayer()-->getString() ---->*linkfunction()*?------->msDrawMap()
                                                filename=layer->data;
2.-loadLayer()-->getString() ---->*linkfunction()*?------->msShapefileOpen()
I know that this  imageObj *msDrawMap(mapObj *map, int querymap) function is
used for rendering the map file. Therefore this function
must know where the data are located ("/usr/local/geo/street")  and DATA
provides this information with (layer-> data) ... but where does it? = S I
can not find the function..
And I  know too that:
loadLayer() this function contain  a (case DATA:)  and  this call the
functions  getString(),msValidateParameter(),msLookupHashTable() and
msFree()..But In what moment DATA sends or provides its value to the
functions msDrawMap() o msShapefileOpen? where is the link function?
I hope you understand me
Thanks
Mauricio
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090719/4692ba3f/attachment.html
