[mapserver-dev] Re: [mapserver-users] msConvertWideStringToUTF8(): General error message. Encoding not supported by libiconv (UTF-16LE)
Daniel Morissette dmorissette at mapgears.com
Thu Jul 23 11:40:09 EDT 2009
OOpps... wrong list, sorry, I meant to sent this to the -users list...
which I just did.
Daniel Morissette wrote:
> (Taking this back on the list)
> Your problem is very likely related to the use of multiple iconv copies
> on your system... that LD_PRELOAD doesn't smell good. Do you absolutely
> need to do that? Why not use the iconv that comes with glibc?
> You wrote that "iconv -l" lists UTF-16LE ... but are you sure that it is
> reporting the info for the same version of iconv that your mapserv
> binary is using?
> The only advice I can provide is make sure you *compile* your MapServer
> with the same copy of iconv that you run with, and that this copy of
> iconv does include UTF-16LE support.
> Daniel
> Mr. Bic Phuong wrote:
>> Dear Daniel,
>> Thanks for your reply,
>> 1. To prevent iconv() in glibc 2.5 I have set this line:
>> export LD_PRELOAD=/usr/local/lib/preloadable_libiconv.so
>> in /root/.bash_profile and
>> SetEnv LD_PRELOAD /usr/local/lib/preloadable_libiconv.so
>> in /etc/httpd/conf/httpd.conf
>> and reboot the server but this didn't solve the problem
>> 2. I found that UTF-16LE is listed in the result of the command "iconv
>> -l"
>> 3. I manual configure and make the file mapserv for first RHEL 5.3.
>> Then I manual configure and make the file mapserv for second RHEL 5.3.
>> I do not copy pre-compiled mapserv.
>> I hope you can help me to solve this problem Daniel !
>> --- On *Thu, 7/23/09, Daniel Morissette /<dmorissette at mapgears.com>/*
>> wrote:
>>     From: Daniel Morissette <dmorissette at mapgears.com>
>>     Subject: Re: [mapserver-users] msConvertWideStringToUTF8(): General
>>     To: mapserver-users at lists.osgeo.org
>>     Date: Thursday, July 23, 2009, 7:48 PM
>>      > I hope someone can solve this problem, our project is delayed by
>>     this error.
>>      > the GetFeatureInfo function is failed:
>>     supported
>>     This error message is telling you that the libiconv library, which
>>     is used by MapServer for encoding conversions, does not support
>>     UTF-16LE on that server.
>>     You need to find out which libiconv your Mapserver was compiled with
>>     and then make sure that copy of libiconv has support for the
>>     UTF-16LE encoding. You can list the encodings supported by libiconv
>>     on a given system using "iconv -l"... make sure UTF-16LE is there.
>>      > this error accured when I'm setting up a webgis on the second
>> Red Hat
>>      > Enterprise Linux (RHEL) 5.3, on the first RHEL 5.3,
>> GetFeatureInfo is
>>      > working perfect.
>>     Look for a difference between the two servers related to libiconv.
>>     Daniel
>>     -- Daniel Morissette
>>     http://www.mapgears.com/
>>     _______________________________________________
>>     mapserver-users mailing list
>>     </mc/compose?to=mapserver-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/mapserver-users
Daniel Morissette
