[mapserver-dev] default values when using url overloading
Thomas Bonfort thomas.bonfort at camptocamp.com
Wed Jul 29 05:59:08 EDT 2009
hi,
the question is most certainly oriented for Steve, but I'm mailing
-dev so others can coment.
I very often use url overloading with the %key% syntax in my mapfile
as I find it's a powerful means of building custom maps. The problem
with the current implementation is that the mapfile more often than
less becomes unparsable if the url doesn't contain the key=value
parameter.
Would it be complicated to modify the parser so that the mapfile can
contain a default value for %key%, that would be applied if the url
does not contain the "key" parameter?
best regards,
thomas
www.camptocamp.com
+33 4 79 26 57 97
