[mapserver-dev] python-mapscript: generateSLD() segfaults
Stephan Holl
stephan.holl at intevation.de
Fri Mar 6 03:22:10 EST 2009
Hello Assefa,
Yewondwossen Assefa <yassefa at dmsolutions.ca>, [20090305 - 16:45:20]
> Stephan,
> I have added a bug and fix
> (http://trac.osgeo.org/mapserver/ticket/2915). If possible, give it a
> try and let me know.
thanks for your fast reply and the proposed fix. I will give it a try
as soon as my admin will install the needed swig-stuff on the maschine
and report back.
Stephan
> Best Regards,
> Stephan Holl wrote:
> > Dear mapServer-devs,
> > using Python-mapscript to write out SLDs for my layers I found out,
> > that some layers did not write an SLD and my script dies with a
> > segfault.
> > Using GDB I get this information from bt:
> > Program received signal SIGSEGV, Segmentation fault.
> > [Switching to Thread 0xb7fd36c0 (LWP 14112)]
> > 0x00769878 in msStringConcatenate at plt ()
> > from /home/gis2/intevation/wms-migration/apps/lib/python2.4/site-packages/_mapscript.so
> > (gdb) bt #0 0x00769878 in msStringConcatenate at plt ()
> > #1 0x0083b7e6 in msSLDGenerateSLD ()
> > #2 0x007b141d in _wrap_layerObj_generateSLD (self=0x0,
> > args=0xb7f680ec) at mapscript_wrap.c:3717 #3 0x4f02645d in
> > PyCFunction_Call () from /usr/lib/libpython2.4.so.1.0 #4
> > 0x4effbd57 in PyObject_Call () from /usr/lib/libpython2.4.so.1.0
> > #5 0x4f05f1bc in PyEval_EvalFrame ()
> > from /usr/lib/libpython2.4.so.1.0 #6 0x4f061c68 in
> > PyEval_EvalCodeEx () from /usr/lib/libpython2.4.so.1.0 #7
> > 0x4f060426 in PyEval_EvalFrame () from /usr/lib/libpython2.4.so.1.0
> > #8 0x4f061c68 in PyEval_EvalCodeEx ()
> > from /usr/lib/libpython2.4.so.1.0 #9 0x4f061cf3 in PyEval_EvalCode
> > () from /usr/lib/libpython2.4.so.1.0 #10 0x4f07e998 in ?? ()
> > from /usr/lib/libpython2.4.so.1.0 #11 0x4f0800a8 in
> > PyRun_SimpleFileExFlags () from /usr/lib/libpython2.4.so.1.0 #12
> > 0x4f08078a in PyRun_AnyFileExFlags ()
> > from /usr/lib/libpython2.4.so.1.0 #13 0x4f087185 in Py_Main ()
> > from /usr/lib/libpython2.4.so.1.0 #14 0x08048582 in main ()
> > bt full gives this:
> > (gdb) bt full
> > No symbol table info available. #1 0x0083b7e6 in msSLDGenerateSLD
> > No symbol table info available. #2 0x007b141d in
> > _wrap_layerObj_generateSLD (self=0x0, args=0xb7f680ec) at
> > mapscript_wrap.c:3717 resultobj = (PyObject *) 0x0 arg1 = <value
> > optimized out> result = <value optimized out> argp1 = (void *)
> > 0x94f5230 res1 = <value optimized out>
> > obj0 = (PyObject *) 0xb7ce764c
> > #3 0x4f02645d in PyCFunction_Call ()
> > I am using MS 5.2.1 and python 2.4.3
> > The Layer it dies has 26 classes with Expressions like this:
> > EXPRESSION "EH "
> > All this is on Oracle Spatial though.
> > Perhaps someone can give me a hint?
> > Stephan
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090306/ee0457b6/signature.bin
