[mapserver-dev] Re: Performance Testing numbers
Stephen Woodbridge woodbri at swoodbridge.com
Sun Mar 8 17:43:01 EDT 2009
Julien-Samuel Lacroix wrote:
> Oh! and the link is:
> http://trac.osgeo.org/mapserver/wiki/PerformanceTesting
These numbers do not look that different, not that you shouldn't look
into them regardless, but your min=270 and max=305 is 35 requests in 20
sec or on avg. 1.75 request per sec delta from your worse to best.
You said: "** Copied the 3 layers in the mapfile multiple times to get a
total of 100 layers. The copied layers were not called like the 3
original ones."
Just so I understand, you are measuring parsing time of the additional
97 layers, but you are not drawing them - correct?
Does the 4th test have project blocks on all the layers also? is this
100 layers or just 3 layers.
Thanks,
   -Steve W
> Julien
>> Hi,
>> I've open a wiki page with some performance testing numbers. I'll add
>> details and explanation as I test.
>> For now I tested the difference between:
>> - simple mapfile mode=map
>> - simple mapfile WMS
>> - 100 layers mapfile mode=map
>> - simple mapfile mode=map with EPSG code
>> There seems to be enough differences between those tests to begin
>> further investigation.
>> Julien
