[mapserver-dev] Vote for MS-RFC-55: Improve control of output resolution
Brent Fraser bfraser at geoanalytic.com
Mon Mar 16 14:29:35 EDT 2009
Or we could add MS_FONTPOINTS as a unit and get rid of the user documentation confusion.
New User: "I changed my RESOLUTION to be 300 dpi so I could print my map, but the text is now too small!"
Experienced User: "Change/Set your LAYER's SIZEUNITS to FONTPOINTS and it will be the same size on the screen and on the printed map no matter what RESOLUTION value you choose."
I know, I know, I already made my pitch.. :)
Brent
Daniel Morissette wrote:
> Paul Spencer wrote:
>> how about RESOLUTION and OUTPUTRESOLUTION where RESOLUTION would be
>> DEFRESOLUTION as defined in the RFC?
> Thought of that one too, but that would mean a change of meaning and
> behavior for the existing RESOLUTION keyword. i.e. all apps that
> currently use RESOLUTION would need to be adapted to use
> OUTPUTRESOLUTION instead (in scripts or in URL params).
> OTOH if we add a new keyword such as DEFRESOLUTION then existing apps
> continue to pass/set resolution the same way. With the proposed
> approach, the only change to existing apps may be to set DEFRESOLUTION
> to be the same value as RESOLUTION if they do not wish to have the
> symbology scaled, but that would be a very very rare case.
> Daniel
