[mapserver-dev] mapscript_csharp removes "include" lines in map file
prak prakashtilhoo at astuntechnology.com
Fri Mar 20 05:45:32 EDT 2009
Hello,
I have a map file, x.map with an include statement, 'INCLDUE "mylayers.map"
I use mapscript_csharp to open x.map and works fine.
However, I observed that immediately after mapobj.open("x.map"), x.map is
saved back on disc with the 'INCLDUE "mylayers.map" '. stripped of x.map and
all layer in "mylayers.map" included directly i x.map.
I would like to keep my 'INCLDUE "mylayers.map" ' in x.map.
Is there a way to do this with mapscript_csharp ?
Thanks a lot for your usual help.
prakash
View this message in context: http://n2.nabble.com/mapscript_csharp-removes-%22include%22-lines-in-map-file-tp2507929p2507929.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
