[mapserver-dev] mapserver 5.4 beta performance test
Guillaume Sueur no-reply at neogeo-online.net
Tue Mar 31 11:57:32 EDT 2009
Thanks for this piece of info Paul. I'm a bit disappointed by the nearly
10 speed factor difference between PostGIS layer and shapefile layer on
that large dataset. I did my test on my personnal PC though. I will test
that on a fast server as well.
Best regards,
Guillaume
Paul Ramsey a écrit :
> I moved from a binary to a text cursor for 5.4, which has a
> performance penalty. It also has a huge code simplicity bonus, which I
> judged worth it (binary cursors have to be managed within transaction
> blocks, which adds a surprisingly high complexity overhead). I changed
> the text encoding during the code sprint, so if your test is using
> code from before then, the next release should be slightly faster,
> though still probably slower than the 5.2 code.
> P.
> On Tue, Mar 31, 2009 at 7:49 AM, Guillaume Sueur
> <no-reply at neogeo-online.net> wrote:
>> Another weird point :
>> If I ask for the whole dataset, 5.4 is slower than 5.2 (11 and 9 secs)
>> but with a filter on an indexed field, I get 0.607s with 5.4 and 2.3s
>> with 5.2.
>> If I use the shapefile of the data I get :
>> whole dataset :
>> 5.4 : 1s
>> 5.2 : 1s
>> with a filter on :
>> 5.4 : 0.76s
>> 5.2 : 0.76s
>> So, as far as I can tell, shapefile still goes much faster than PostGIS
>> layers, with various differences between 5.2 and 5.4
>> 5.2 and 5.4 are equal when dealing with shapefiles.
>> Does this sound ok for you devs ?
>> Regards
>> Guillaume
>> Guillaume Sueur a écrit :
>>> Hi,
>>> I'd like to share some strange results I've got back when testing
>>> mapserver 5.4 beta on a huge streets postgis layer.
>>> here are the tests :
>>> 5.4 beta DEBUG ON -----------------------------------------------
>>>  time /usr/local/src/mapserver-5.4.0-beta3/shp2img -m test.map
>>> [Tue Mar 31 15:49:15 2009].935351 msDrawMap(): Layer 0 (streets), 1.617s
>>> [Tue Mar 31 15:49:15 2009].935551 msDrawMap(): Drawing Label Cache, 0.000s
>>> [Tue Mar 31 15:49:15 2009].935603 msDrawMap() total time: 1.619s
>>> [Tue Mar 31 15:49:16 2009].24176 msSaveImage() total time: 0.089s
>>> [Tue Mar 31 15:49:16 2009].24347 msFreeMap(): freeing map at 0x818f8e0.
>>> real  0m1.719s
>>> user  0m0.284s
>>> sys   0m0.028s
>>> 5.4 BETA DEBUG OFF ---------------------------------------------
>>>  time /usr/local/src/mapserver-5.4.0-beta3/shp2img -m test.map -o test.png
>>> real  0m1.994s
>>> user  0m0.408s
>>> sys   0m0.020s
>>> as you can see it goes faster with debug ON (tested several times)
>>> if I try it back with mapserver 5.2 I get :
>>> 5.2 DEBUG ON -----------------------------------------------
>>> time /usr/local/src/mapserver-5.2.0/shp2img -m test.map -map_debug 5 -o
>>> [Tue Mar 31 15:52:01 2009].891334 msDrawMap(): Layer 0 (streets), 1.434s
>>> [Tue Mar 31 15:52:01 2009].891549 msDrawMap(): Drawing Label Cache, 0.000s
>>> [Tue Mar 31 15:52:01 2009].891603 msDrawMap() total time: 1.437s
>>> [Tue Mar 31 15:52:02 2009].43083 msSaveImage() total time: 0.151s
>>> [Tue Mar 31 15:52:02 2009].43240 msFreeMap(): freeing map at 0x81878e0.
>>> real  0m1.599s
>>> user  0m0.268s
>>> sys   0m0.016s
>>> 5.2 DEBUG OFF  -----------------------------------------------
>>>  time /usr/local/src/mapserver-5.2.0/shp2img -m test.map -o test.png
>>> real  0m1.481s
>>> user  0m0.296s
>>> sys   0m0.008s
>>> So the 5.4beta seems definitely slower than 5.2, and goes even slower
>>> when DEBUG is off.
>>> Is there a special setting activated by default on beta releases which
>>> could explain that ?
>>> Best regards
>>> Guillaume
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
