[mapserver-dev] exported SLDs lacking ogc:Filter-definition for classification
Stephan Holl stephan.holl at intevation.de
Fri May 15 05:17:24 EDT 2009
Hello MapServer-devs,
I am exporting a Mapfile to SLD using pythons
layer.generateSLD()-method.
Assefa already provided some fixes for that in the past. For now I
found another oddity inside the generated SLDs:
My layer-definition in the mapfile:
LAYER
    CONNECTION "xx/xx at xx"
    CONNECTIONTYPE ORACLESPATIAL
    DATA "geom from ISAL..."
     METADATA
        "wms_srs"       "EPSG:325833"
        "wms_layer_group"
"/Fachinfo/Umwelt/Boden_und_Abfallwirtschaft/Kom: Altlast"
        "wms_extent"    "3376670 5693050 3412800 5742770"
        "wms_title"     "Altlast: Typ"
      END
    NAME "altlast_typ"
    SIZEUNITS PIXELS
    STATUS ON
    TOLERANCE 10
    TOLERANCEUNITS PIXELS
    TRANSPARENCY 100
    TYPE POINT
    UNITS METERS
#    CLASSITEM CODE
    CLASS
      EXPRESSION ('[CODE]'>='70000' and '[CODE]'<'80000')
      NAME "Stoffl. schaedl. Bodenveraenderung: saniert"
      MINSCALE 50000
      METADATA
      END
      STYLE
        SIZE 7
        COLOR 0 0 0
        SYMBOL "triangle"
      END
      TEMPLATE "../html/altlast_typ.html"
    END
END
The resulting sld lacks a Filter-property to classify the layer
correctly (as it is done within the mapfile):
<StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc" xml
ns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0"
xsi:schemaLocation="http://ww w.opengis.net/sld
http://10.224.1.83/schemas/sld/1.0.0/StyledLayerDescriptor.xsd">
<NamedLayer> <Name>altlast_typ</Name> <UserStyle> <FeatureTypeStyle>
<Rule> <Name>Stoffl. schaedl. Bodenveraenderung: saniert</Name>
          <MinScaleDenominator>50000.000000</MinScaleDenominator>
          <PointSymbolizer>
            <Graphic>
              <Mark>
                <WellKnownName>triangle</WellKnownName>
                <Fill>
                  <CssParameter name="fill">#0000ff</CssParameter>
                </Fill>
              </Mark>
              <Size>7</Size>
            </Graphic>
          </PointSymbolizer>
        </Rule>
     </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
Is this a bug? Could someone have a look at this situation?
Best
	Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090515/321f1853/signature.bin
