[mapserver-dev] raster rewind
David Fuhry dfuhry at acm.org
Fri May 15 14:37:00 EDT 2009
I just hit a savepoint working on an experimental patch to mapdraw.c,
which I'm calling "raster rewind".  It's not intended for general use.
When dealing with a patchwork of raster imagery, where a hi-res layer
may cover up a broader low-res layer, then the patch can help to discard
unnecessary low-res layers.  I post it, in case someone finds it
interesting.
The idea is that if a hi-res layer renders a fully opaque image, then it
was not necessary to process any lower-level layers that preceded it.
To determine the former condition, visible raster layers are first
iterated through *backwards*, each rendered into its own temporary image
buffer.
If, when iterating backwards, a layer renders a fully opaque image, then
we can start mapfile layer processing at that index, rather than 0.
Intuitively, that layer would cover any previous layers' renderings.
Later, I intend to implement a transparency threshold, rather than an
all-or-nothing opaqueness measure, since some of our raster layers have
just a few (~ 0.0002%) pixels which match the OFFSITE (transparent) color.
This patch does not handle skipped layers which may have rendered labels.
-Dave
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090515/90e56cef/mapdraw_raster_rewind.v1.bin
