[mapserver-dev] SOS responseFormat
bartvde at osgis.nl bartvde at osgis.nl
Tue May 19 05:05:26 EDT 2009
Hi list,
these are my first steps into the SOS field. I am trying to write an SOS
client in OpenLayers based on the work from Till Adams, and I am testing
against:
-Mapserver
-52North
However, it seems there is already a discrepancy between the two
implementations about the correct value of responseFormat.
52North wants (note the quotes around subtype value)
text/xml;subtype="om/1.0.0"
Mapserver wants:
text/xml; subtype=om/1.0.0
If I look at the OGC spec it seems 52North is more right. Although 52North
cannot deal with a space after the ; which seems a bit weird to me. The
spec examples also use a space in between.
Any SOS expert willing to comment on this? Since right now this is
breaking interoperability :-)
TIA.
Best regards,
Bart
