[mapserver-dev] Problems for adding a new keyword in MapServer
Steve Lime Steve.Lime at dnr.state.mn.us
Sat May 23 11:34:54 EDT 2009
Although running flex independently shouldn't harm anything. The steps seem fine
and the error suggests a flex version problem. What are you using?
I'd suggest upgrading flex and trying again.
Steve
>>> Alan Boudreault <aboudreault at mapgears.com> 05/23/09 9:35 AM >>>
Hi Mauricio,
You should not have to run flex by yourself. The MapServer Makefile will
do it. Make sure you did a "make clean" and a "make" to regenerate
everything.
Thanks,
Alan
Mauricio Herrera wrote:
> Hi developer community
> Could you help me??
> I am trying  to add  a new keyword in MapServer (Only for experimental
> purpose).. but I could not do it. I just want that my keyword is
> detected (recognized) by the MapServer (mapserv)  when I write the
> keyword in the mapfile (.map)
> Until now I have modified the next files:
>     * *maplexer.l *:   I added this declaration
>       <INITIAL,URL_VARIABLE>start { return(START); } */      I am
>       using this syntax: flex -Pmsyy -i -omaplexer.c maplexer.l  for
>       compiling maplexer.l
>     * *mapfile.h* :  I added new keyword and id   # Define START 1300
>     * *mapfile.c*:  only  I added the new keyword in a SWITCH of
>       loadclass function     CASE START: printf ("Keyword is
>       here");break; */
>        After I did  MAKE in the command line for compiling these
> files.  And inmediatly these errors appear:
> ./libmapserver.a(mapfile.o): In function `msUpdateQueryMapFromString':
> mapfile.c:(.text+0x65af): undefined reference to `msyylex_destroy'
> ./libmapserver.a(mapfile.o): In function `msUpdateReferenceMapFromString':
> mapfile.c:(.text+0x69f2): undefined reference to `msyylex_destroy'
> ./libmapserver.a(mapfile.o): In function `msUpdateStyleFromString':
> mapfile.c:(.text+0x705f): undefined reference to `msyylex_destroy'
> ./libmapserver.a(mapfile.o): In function `msUpdateScalebarFromString':
> mapfile.c:(.text+0x7daf): undefined reference to `msyylex_destroy'
> ./libmapserver.a(mapfile.o): In function `msUpdateLegendFromString':
> mapfile.c:(.text+0x81d5): undefined reference to `msyylex_destroy'
> ./libmapserver.a(mapfile.o):mapfile.c:(.text+0x8258): more undefined
> references to `msyylex_destroy' follow
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> *My questions are:*
> Should I modify other files for adding a new keyword? or Should I need
> to do another thing ( maybe  write "special command" or declaration)?
> *Additional information*
> I have installed on my pc
> Mapserver 5.2.1
> Flex 2.5.4a.-41
> S.O. CentOS 5
> Bison 2.3.2.1
> Thank you so much!
> Mauricio
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
Mapgears
http://www.mapgears.com/
