[mapserver-dev] Labeling enhancements
Daniel Morissette dmorissette at mapgears.com
Wed May 27 15:20:21 EDT 2009
We're looking at making a couple of enhancements to the labelling
algorithm to add more labels along long line or multiline shapes, and
before I go ahead and write a RFC I would like to discuss this here and
see if anyone has thoughts on this.
1- Label all the lines in a MultiLine shape:
At the moment, if you've got a MultiLine shape (i.e. a shapeObj with
numlines > 1) then only the longest of the Lines is labelled. This is
fine in most cases, but in some cases, we may want each individual Line
in the MultiLine to get a label. That's the first enhancement that I
would like to propose: make it possible to label all lines in a
MultiLine shape.
2- Ability to repeat labels along a line with ANGLE FOLLOW
At the moment, with ANGLE FOLLOW, a label is placed at the center of the
line. In the case of very long lines (roads), and especially when using
metatiles to render a tile cache, we may want to repeat the label at
some interval along the line. That's the second enhancement: make it
possible to repeat the label at a given interval along a line when using
ANGLE FOLLOW.
A possible way to control this in the mapfile could be to add a
LABEL.REPEATDISTANCE parameter. By default this would be turned off and
we would keep the current behavior. If REPEATDISTANCE is set to any
value > 0 then the labels would be repeated on every line of a multiline
shape (#1 above), and would be repeated multiple times along a given
line at an interval of REPEATDISTANCE pixels (#2 above). In all cases
the MINDISTANCE value would still be handled by the label cache so that
multiple labels ending up too close to each other for various reasons
would be eliminated by the label cache.
Since a picture is worth a thousand words, I have attached a picture
showing what we currently get with a multiline and what we would like to
get using the new REPEATDISTANCE keyword.
Any thoughts on this before I write a RFC?
Suggestions of a better name for the REPEATDISTANCE keyword?
Should we consider having separate keywords to control #1 (label each
line in a multiline) and #2 (repeat labels along a line)?
Daniel
Daniel Morissette
http://www.mapgears.com/
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090527/fbd0e584/repeat_label.gif
