[mapserver-dev] strange behavior when size != gif size (UMN 5.4.2)
teeschke daniel.teske at web.de
Mon Nov 2 14:18:52 EST 2009
Dear Jeff, Normand
nearly two month went and nothing changed on ms4w?
version 3.0 beta7 is still the recent version and includes the bug number
2094
best regards,
Daniel
Jeff McKenna wrote:
> Steve Lime wrote:
>> I will... In your version line there's 'SUPPORTS=RGBA_PNG' which is the
>> signature for
>> the experimental PNG support. Wonder what versions are used by mapserver
>> and then
>> GD? Does IMAGETYPE JPEG work for you?
> Steve,
> Older MS4W versions are fine, so I guess you are right, it must be some
> conflict in GD and MapServer.  Darn.
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
View this message in context: http://n2.nabble.com/Re-strange-behavior-when-size-gif-size-UMN-5-4-2-tp3558359p3934042.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
