[mapserver-dev] mapserver performance windows/linux
JUDD.CHRISTOPHER JUDD.CHRISTOPHER at flsenate.gov
Thu Sep 17 15:51:07 EDT 2009
Andy,
That looks pretty close to the numbers that I am getting.
Steve, will that suffice for the profiling?  I guess it would be nice to
look at the differences between ms4w 2.3.1 and 3 beta 7.
I'd like to do whatever I can to help identify this as a bug and try to
get it fixed.
Thanks,
Chris
-----Original Message-----
Sent: Thursday, September 17, 2009 3:27 PM
To: JUDD.CHRISTOPHER
Cc: Alan Boudreault; mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] mapserver performance windows/linux
JUDD.CHRISTOPHER wrote:
> That is right, I did find this same performance issue with 5.0, 5.2
and
> 5.4 on linux.
> I just tested ms4w_3.0_beta7 and it is taking about 3.7 seconds to
draw
> the same image that 2.3.1 did in 1.4 seconds.
> Someone else should probably do the same testing to make sure that I'm
> not off base.
> How do I do the profiling?
> Thanks for your help,
> Chris
On Linux its easy.  recompile with -pg, then run it once which will dump
out a gmon.out, then use the gprof to view it.
No idea on windows.
I used shp2img because I dont have php script compiled.  I downloaded
your test set and changed the mapfile extent to match what you had in
the php script.
shp2img takes 2.6 seconds to render, and my images came out a lot like
yours.  (I'm also using mapserver 5.6)
I tried it with both gd and agg and it didnt seem to make a difference.
  But changing to ANGLE AUTO made it run in 0.8 seconds.
Here are my gprof dumps.
AGG, ANGLE FOLLOW:
Flat profile:
Each sample counts as 0.01 seconds.
   %   cumulative   self              self     total
  time   seconds   seconds    calls  ms/call  ms/call  name
100.00      0.01     0.01      758     0.01     0.01  msClipPolylineRect
   0.00      0.01     0.00    82305     0.00     0.00  msRectOverlap
   0.00      0.01     0.00    67590     0.00     0.00
intersectLabelPolygons
   0.00      0.01     0.00    36963     0.00     0.00
msIntersectSegments
   0.00      0.01     0.00    32460     0.00     0.00  msGetBit
   0.00      0.01     0.00    16988     0.00     0.00  msSHXReadSize
AGG, ANGLE auto:
Flat profile:
  no time accumulated
  time   seconds   seconds    calls  Ts/call  Ts/call  name
   0.00      0.00     0.00    98521     0.00     0.00  msRectOverlap
   0.00      0.00     0.00    83806     0.00     0.00
   0.00      0.00     0.00    32460     0.00     0.00  msGetBit
   0.00      0.00     0.00    16988     0.00     0.00  msSHXReadSize
   0.00      0.00     0.00    15472     0.00     0.00  msSHXReadOffset
   0.00      0.00     0.00    14715     0.00     0.00  msSHPReadBounds
   0.00      0.00     0.00     4067     0.00     0.00  msFree
