[mapserver-dev] Mapscript Raster Query Problem
Thu Apr 8 18:36:23 EDT 2010
geographika wrote:
> Hi list,
> I have some Python code running on MapScript which queries a raster
> layer by an input point. The following lines:
>     for i in range(layer.numitems):
>             print '%s: %s' % (layer.getItem(i), s.getValue(i))
> With this I get the output below:
> x: 249975
> y: 249975
> value_0: 3
> value_list: 3
> class: 50-100m
> red: 162
> green: 180
> blue: 189
> But no matter which points I use the class and the rgb values remain the
> same. However the value_0 and value_list are always correct. I have a
> hack to get the correct class based on the value, but I'd appreciate any
> further clarification on why the same values are always returned. The
> raster displays without problems through MapServer showing the correct
> classes for each pixel.
> Regards,
Seth,
If you can file a detailed ticket I am interested in investigating this
problem.
Best regards,
