[mapserver-dev] Mapserver 5.6 PHP-MapscriptCrash (processquerytemplate)
Dieter Zuberbühler dieter.zuberbuehler at gogis.ch
Thu Apr 29 03:38:17 EDT 2010
i found the problem...
it's a side effect metioned in the migration guide...
MapServer 5.4 to 5.6 Migration Guide
RFC 36 added support for templated outptformats, but this new feature
was not available for WMS GetFeatureInfo ouptut (see ticket #3024).
In MapServer 5.6 this has been resolved by implementing lookup of output
formats for query templates by mime-type. However this caused a conflict
for the text/html mime-type between the actual text/html query
templates and the preconfigured imagemap outputformat which also used the
text/html mime-type.
In order to resolve this conflict, the mime-type of the imagemap
outputformat
has been changed to "text/html; driver=imagemap". This is unlikely to cause
much side-effects to existing applications, but the change is documented
here
just in case.
i had this in my mapfile (but don't use it at all->selected format was gif):
  OUTPUTFORMAT
    NAME "imagemap"
    MIMETYPE "text/html"
    DRIVER "imagemap"
  END
if i remove this outputformat completely or change it to:
  OUTPUTFORMAT
    NAME "imagemap"
    MIMETYPE ""text/html; driver=imagemap""
    DRIVER "imagemap"
  END
everything is fine!!!
i tested the function 'processquerytemplate' with postgis and shapefile
layers...
thanks dieter
----- Original Message -----
From: "Alan Boudreault" <aboudreault at mapgears.com>
To: <mapserver-dev at lists.osgeo.org>; "Dieter Zuberbühler"
<dieter.zuberbuehler at gogis.ch>
Cc: "Daniel Morissette" <dmorissette at mapgears.com>
Sent: Wednesday, April 28, 2010 4:14 PM
Subject: Re: [mapserver-dev] Mapserver 5.6 PHP-MapscriptCrash
I'm mostly sure that the processquerytemplate and processtemplate are
broken.
I remember that I couldn't get them to work with 5.6 when I was testing the
php refactoring things.
Alan
On April 28, 2010 10:07:37 am Dieter Zuberbühler wrote:
> thanks ...
> anybody else tested/used processquerytemplate since the 5.6 release?
> anybody else with the same problem?
> i'll try it with another data source than postgis...
> ...and open a ticket with an example soon.
> dieter
> From: "Daniel Morissette" <dmorissette at mapgears.com>
> Sent: Wednesday, April 28, 2010 3:11 PM
> > It is quite possible that this function may have been overlooked in the
> > transition to the new query mechanism.
> > The best would be for you to file a ticket about this with a simple test
> > case to reproduce, so that we don't forget about the issue, and that one
> > of us has a look when we have a minute.
> > Daniel
> >> hi all,
> >>  can anybody confirm to me, that the function processquerytemplate of
> >> the mapObj still works in PHP-Mapscript 5.6.x (used with postgis
> >> layers)? if so, what has changed since 5.4.x (i didnt't saw anything in
> >> the migration guide...) or is this a bug, since the implementation of
> >> single pass queries?
> >>  i used this function in PHP-Mapscript 4.10 / 5.2 / 5.4 whithout any
> >> problem... but in all versions of 5.6 i've tested, the php script ends
> >> up with a crash (no response, no error message)
> >>  i tried:
> >> fedora 11, php 5.2 mapserver (compiled)
> >> fedora 12 php 5.3 mapserver (binary, compiled)
> >> ubuntu 9.1 php 5.2 mapserver (binary: ubuntugis)
> >> ubuntu 10.04 php 5.3 mapserver (binary: standard)
> >>  thanks for any reply
> >>  dieter
> >>  (i posted this to mapserver-users list too: i'm not sure, wether this
> >> is a user and/or development problem)
> >> GOGIS Dieter Zuberbühler
> >> CH-4142 Münchenstein
> >> www.gogis.ch <http://www.gogis.ch>
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
Mapgears
http://www.mapgears.com
