[mapserver-dev] Call for a 5.6.1 release...
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jan 5 09:55:35 EST 2010
OK, that was what I was missing, thanks.
-Steve
Lime, Steve D (DNR) wrote:
> I don't see class names in your data. Without those a legend will be
> blank regardless of layer status. Yes, legends do support TTF...
> Steve
> -----Original Message----- From:
> mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge Sent: Sunday, January 03, 2010 11:22 PM To: Lime, Steve D
> (DNR) Cc: mapserver-dev at lists.osgeo.org Subject: Re: [mapserver-dev]
> Steve,
> http://imaptools.com:8080/work/testMapfile2.php
> This is NOT PHP/Mapscript, I'm using the php to parse the a php
> object and turn it into the mapfile, the write the mapfile to a
> temporary file and generate the image. The LegendIcons work under the
> map, you can see the gray mark in the lower left of the map which
> should be the legend. Do legends work with truetype fonts? the map
> image is just a cgi request.
> The generated mapfile is listed above the map.
> Thanks, -Steve
>> Hi Steve: Both a mode=legend and and embedded legend work for me:
>> http://maps.dnr.state.mn.us/cgi-bin/mapserv54?map=COMPASS_MAPFILE&mode=map&map.legend=STATUS+EMBED
>> http://maps.dnr.state.mn.us/cgi-bin/mapserv56?map=COMPASS_MAPFILE&mode=map&map.legend=STATUS+EMBED
>> http://maps.dnr.state.mn.us/cgi-bin/mapserv54?map=COMPASS_MAPFILE&mode=legend
>> http://maps.dnr.state.mn.us/cgi-bin/mapserv56?map=COMPASS_MAPFILE&mode=legend
>> This mapfile has all default layers. Here's an example with layer
>> toggling (version 5.4 works as well)...
>> http://maps.dnr.state.mn.us/cgi-bin/mapserv56?mode=map&map.legend=STATUS+EMBED&map=LANDVIEW_MAPFILE&mapext=420300.72018349805+4967108.039017859+521038.99713614146+5031580.536267551&mapsize=750+480&layers=bdry_stforpy3+bdry_adwma2py3+bdry_snapy3&layer=bdry_statepy2
>> Guess we'll need more info...
>> Steve
>> ________________________________________ From:
>> [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
>> Woodbridge [woodbri at swoodbridge.com] Sent: Saturday, January 02,
>> 2010 5:06 PM To: Lime, Steve D (DNR) Cc:
>> mapserver-dev at lists.osgeo.org Subject: Re: [mapserver-dev] Call for
>> a 5.6.1 release...
>>> Hi all: I just fixed a couple of inconvenient bugs in 5.6 that
>>> broke some point-based queries via the CGI. Without the fixes
>>> some folks won't be able to upgrade. I've got a whole bunch of
>>> query test cases I need to get into the automated testing to
>>> avoid this in the future. Are others sitting on changes in the
>>> 5.6 trunk that could go into 5.6.1?
>>> Steve
>>> BTW Ticket is http://trac.osgeo.org/mapserver/ticket/3246...
>> Steve,
>> Can you verify the Legends embeded in the image work correctly? I
>> just tried to generate one and I'm having troubles getting anything
>>  that looks like a legend to show up. I'm in rc5, but will upgrade
>> to the released version and see if the makes a difference.
>> LEGEND IMAGECOLOR "#CCCCCC" OUTLINECOLOR "#000000" STATUS embed
>> POSITION lr KEYSIZE 40 40 KEYSPACING 5 5 LABEL FONT "arial" SIZE 10
>>  TYPE TRUETYPE COLOR '#000000' END END
>> Also tried it with mode=legend an get the same blank image. If its
>> a bug let me know and I'll write a ticket if you want.
>> Thanks, -Steve W
>> PS: Happy New Year Everyone.
>> _______________________________________________ mapserver-dev
>> mailing list mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> _______________________________________________ mapserver-dev mailing
