[mapserver-dev] Content-Type versus Content-type
Jan Hartmann j.l.h.hartmann at uva.nl
Fri Jan 15 08:35:50 EST 2010
Hi Bart,
The HTTP specification (http://tools.ietf.org/html/rfc2616) says:
      4.2 Message Headers
    HTTP header fields, which include general-header (section 4.5  <http://tools.ietf.org/html/rfc2616#section-4.5>),
    request-header (section 5.3  <http://tools.ietf.org/html/rfc2616#section-5.3>), response-header (section 6.2  <http://tools.ietf.org/html/rfc2616#section-6.2>), and
    entity-header (section 7.1  <http://tools.ietf.org/html/rfc2616#section-7.1>) fields, follow the same generic format as
    that given inSection 3.1 of RFC 822  <http://tools.ietf.org/html/rfc822#section-3.1>  [9  <http://tools.ietf.org/html/rfc2616#ref-9>]. Each header field consists
    of a name followed by a colon (":") and the field value. Field names
    are case-insensitive.
What's your problem whith a lower case "t"? Content-type is an
entity-header, so applications should accept both T and t .
Jan
On 15-1-2010 14:04, bartvde at osgis.nl wrote:
> Hi list,
> I am having issue with Mapserver outputting Content-type in the body
> instead of in the headers. I found that this is because Mapserver outputs
> Content-type instead of Content-Type in a lot of cases. Should this not be
> fixed in the source? Am I the only one running into this, and if so, how
> come?
> For instance:
> [bart at hades mapserver-5.2.0]$ curl
> "http://145.50.148.45:8081/cgi-bin/mapserv?map=/data/OGC_UMN_services/dtb_rws.map&LAYERS=AAA805&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_xml&SRS=EPSG%3A28992&BBOX=80410.227496%2C433911.299646%2C84251.633167%2C435237.721003&X=462&Y=108&INFO_FORMAT=text/xml&QUERY_LAYERS=AAA805&FEATURE_COUNT=1&WIDTH=1031&HEIGHT=356"
> --verbose
> * About to connect() to 145.50.148.45:8081
> * Connected to rws-svl023i.rws.nwr.local (145.50.148.45) port 8081
>> GET
> HTTP/1.1
> User-Agent: curl/7.10.6 (i386-redhat-linux-gnu) libcurl/7.10.6
> OpenSSL/0.9.7a ipv6 zlib/1.1.4
> Host: 145.50.148.45:8081
> Pragma: no-cache
> Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, */*
> <  HTTP/1.1 200 OK
> <  Date: Fri, 15 Jan 2010 12:46:24 GMT
> <  Server: Apache
> <  Transfer-Encoding: chunked
> <  Content-Type: text/xml
> Content-type: application/vnd.ogc.se_xml
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msReturnPage(): Unable to access file. blank.html
> </ServiceException>
> </ServiceExceptionReport>
> * Connection #0 left intact
> * Closing connection #0
> TIA.
> Best regards,
> Bart
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100115/83e4a390/attachment-0001.html
