[mapserver-dev] Possible bug found
Guillaume Sueur no-reply at neogeo-online.net
Thu Jan 21 06:08:34 EST 2010
I've faced a strange situation where all layers of a map (turned off by
default) were showing when requesting a specific layer in WMS.
layers are :
	selection
	departement
	region
	selection_label
when asking for selection layer, all others layer were showing. renaming
selection to something else and asking still for selection layer had the
same result, a full map.
The only clue I've found is that my map is named selection.Changing it
to whatever else solves the problem.
Is this conflict between map name and layer name a normal behaviour ?
Regards,
Guillaume
