[mapserver-dev] Possible bug found
Dan Little danlittle at yahoo.com
Thu Jan 21 09:03:51 EST 2010
If your map name is "selection" and you request "selection," MapServer believes you are requesting the entire map.  This is an "undocumented feature."
----- Original Message ----
> From: Guillaume Sueur <no-reply at neogeo-online.net>
> To: MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
> Sent: Thu, January 21, 2010 5:08:34 AM
> Subject: [mapserver-dev] Possible bug found
> Hi,
> I've faced a strange situation where all layers of a map (turned off by
> default) were showing when requesting a specific layer in WMS.
> layers are :
>     selection
>     departement
>     region
>     selection_label
> when asking for selection layer, all others layer were showing. renaming
> selection to something else and asking still for selection layer had the
> same result, a full map.
> The only clue I've found is that my map is named selection.Changing it
> to whatever else solves the problem.
> Is this conflict between map name and layer name a normal behaviour ?
> Regards,
> Guillaume
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
