[mapserver-dev] Possible bug found
Guillaume Sueur no-reply at neogeo-online.net
Thu Jan 21 09:25:59 EST 2010
Le jeudi 21 janvier 2010 à 06:03 -0800, Dan Little a écrit :
> If your map name is "selection" and you request "selection," MapServer believes you are requesting the entire map.  This is an "undocumented feature."
quite disturbing in WMS mode though.
Thanks for the hint
Guillaume
> ----- Original Message ----
> > From: Guillaume Sueur <no-reply at neogeo-online.net>
> > To: MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
> > Sent: Thu, January 21, 2010 5:08:34 AM
> > Subject: [mapserver-dev] Possible bug found
> > Hi,
> > I've faced a strange situation where all layers of a map (turned off by
> > default) were showing when requesting a specific layer in WMS.
> > layers are :
> >     selection
> >     departement
> >     region
> >     selection_label
> > when asking for selection layer, all others layer were showing. renaming
> > selection to something else and asking still for selection layer had the
> > same result, a full map.
> > The only clue I've found is that my map is named selection.Changing it
> > to whatever else solves the problem.
> > Is this conflict between map name and layer name a normal behaviour ?
> > Regards,
> > Guillaume
> > mapserver-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
