[mapserver-dev] Website...
Alan Boudreault aboudreault at mapgears.com
Mon Jan 25 10:56:56 EST 2010
Steve,
The URL flags problem is a known issue. We realized that the makefile "target"
setting was not recognized in the template code. I've re-modified the layout
template on the server and started the doc regeneration. This should fix the
problem.
Alan
On January 25, 2010 10:41:28 am Lime, Steve D (DNR) wrote:
> I committed the design changes to the 5.6 docs tree last night. One change
>  I had made was moving the language icons from the toc to the header. I
>  thought they stood out better up there. Anyway, here's a question for the
>  sphinx guru's. How'd the flags show up back in the toc and why are the
>  URLs for those in the header wrong? I didn't edit the template code, just
>  moved it from the sidebar block to the relbar1 block...
> I've not added to trunk, figured there might be a bug or two to fix first.
> Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
Mapgears
http://www.mapgears.com
