[mapserver-dev] WMS and cookies
Bart van den Eijnden bartvde at osgis.nl
Wed Jan 27 09:58:46 EST 2010
Hi Assefa,
my patch just disables the cookies since I did not need that functionality, so it is too blunt.
See also Steve's reaction here:
http://lists.osgeo.org/pipermail/mapserver-dev/2008-July/007514.html
Best regards,
Bart
On Jan 27, 2010, at 3:29 PM, Yewondwossen Assefa wrote:
> Bart van den Eijnden wrote:
>> Hi,
>> see below from wms-dev, Mapserver in WMS mode will give cookies preference over URL parameters. I've always found this unwanted, so I have my own custom patch for it, which I now want to get rid off :-)
>> Would it be worthwhile changing this in Mapserver? CGI mode can remain the same.
>> Objections? Thoughts?
> Bart,
> I agree with you that that overwriting url parameters by cookies  is an unwanted behavior  for both OGC and CGI. Maybe It should be the other way around; It would change the current behavior but  I could not find in MapServer  docs explaining the current behavior so I tend to believe that It is not used consciously by a lot of users.
> What does your patch do?
> regards,
>> Best regards,
>> Bart
>> Begin forwarded message:
>>> *From: *Raj Singh <raj at rajsingh.org <mailto:raj at rajsingh.org>>
>>> *Date: *January 26, 2010 3:38:12 PM GMT+01:00
>>> *To: *bartvde at osgis.nl <mailto:bartvde at osgis.nl>
>>> *Cc: *wms-dev at lists.eogeo.org <mailto:wms-dev at lists.eogeo.org>
>>> *Subject: **Re: [wms-dev] WMS and cookies*
>>> The spec doesn't say anything about cookies, so they should be ignored by a WMS implementation.
>>> Raj
>>> On Jan 26, at 3:13 AM, bartvde at osgis.nl <mailto:bartvde at osgis.nl> wrote:
>>>> Hi list,
>>>> what is the policy of WMS wrt cookies? I could not find anything in the spec.
>>>> If a WMS receives a cookie param named LAYERS for instance, does it take
>>>> precedence over the url parameter? Or should a WMS ignore cookies?
>>>> Best regards,
>>>> Bart
>>>> _______________________________________________
>>>> wms-dev mailing list
>>>> http://lists.eogeo.org/mailman/listinfo/wms-dev
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Assefa Yewondwossen           Software Analyst
> Email: assefa at dmsolutions.ca    http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
