[mapserver-dev] problems when compiling mapserver from source code
Fri Jul 16 10:49:56 EDT 2010
stephan_82 wrote:
> Hello members!
> First I want to apologize for my bad english. I hope that I can explain my
> problem still good enough.
> I just install mapserver in version 5.6.3. on CENTOS 5.5. When I configure
> the source code and then run make, it is an error. I suspect that the
> problem is that my OpenSSL library is newer than the mapserver needed.
> My ./configure command looks like this:
>        ./configure --with-postgis=/usr/local/pgsql/bin/pg_config
>                       --with-proj
>                       --with-geos
>                       --with-gdal
>                       --with-ogr
>                       --with-wfs
>                       --with-wcs
>                       --with-sos
>                       --with-curl
>                       --with-wmsclient
>                       --with-wfsclient
>                       --with-php=/opt/PostgreSQL/EnterpriseDB-ApachePhp/php
>                       --with-jpeg (but nothing happened)
>                       --with-png (nothing happened)
> The error after the make command looks like this.
> http://osgeo-org.1803224.n2.nabble.com/file/n5301205/mapserver_fehler.jpg
Stephan,
It looks like you have an old version of libpq - the postgres client
library - in /usr/local/lib.  Perhaps you could clean that out and
use one provided with centos?  Or rebuild it against the ssl lib on
your system.
Best regards,
