[mapserver-dev] The legendary story of mapObj.zoomRectangle (a cabaret show)
Tamas Szekeres szekerest at gmail.com
Thu Mar 4 14:38:01 EST 2010
I also have a breaking issue with the MSSQL 2008 driver which I would fix in
this weekend, and I couldn't still finish my testing with my existing
mapfiles against 5.6.2.
I suggest to prepare a release during the next week.
Best regards,
Tamas
2010/3/4 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> I'd like to take a peek at the isValidItem() issue before doing a 5.6.2...
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:
> mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan Boudreault
> Sent: Wednesday, March 03, 2010 3:47 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] The legendary story of mapObj.zoomRectangle (a
> cabaret show)
> Tamas,
> Someone also reported on IRC that problem (IIRC, 2-3 weeks ago). My change
> was
> a misinterpretation and shouldn't have been done. I had not understood why
> this part of the code was different of the php similar function. As you
> said
> on IRC "treating maxy >= miny as a failure is semantically irregular", but
> this commit changed the behavior of the function that exists for a long
> time.
> I would suggest to revert it and backport it in branch 5.6.
> Perhaps it would be a good opportunity to release 5.6.2 ? Are there enough
> important fixes in the branch?
> regards,
> Alan
> On March 3, 2010 03:49:54 pm Tamas Szekeres wrote:
> > Folks,
> > Upon upgrading my existing application to 5.6.1 I'm getting frustrated
> >  about the changes of the rectangle check in mapObj.zoomRectangle. So let
> >  me summarize how the related code have changed within the past 5 years.
> > - 2004-06-26 The stuff has been committed by sean in r3294 mapzoom.i Ln
> 280
> > if (poPixRect->maxy >= poPixRect->miny)
> >             msSetError(MS_MISCERR, "Georeferenced coordinates miny <=
> >  maxy", "mapscript::mapObj::zoomRectangle()");
> >             return MS_FAILURE;
> > - 2006-05-30  First attempt to swap miny and maxy by umberto in r5472
> > - 2006-07-24  The change have been reverted by hobu in r5542
> > - 2006-12-13 Second attempt to swap miny and maxy by sdlime in r5859
> > - 2006-12-13 Reverted the change by sdlime in r5864
> > - 2009-10-12 Third attempt to swap miny and maxy by aboudreault in r9444
> > There have been a couple of tickets related to this issue like:
> > http://trac.osgeo.org/mapserver/ticket/1817
> > http://trac.osgeo.org/mapserver/ticket/1982
> > http://trac.osgeo.org/mapserver/ticket/1988
> > http://trac.osgeo.org/mapserver/ticket/3286
> > While I'm a bit lost with the reason of these reverts it seems we don't
> >  have solid standpoint on how this consistency check should be done. I
> >  would anticipate I'm not against this change, however I would not want
> to
> >  alter my existing scipts (like now) in every release in order to have my
> >  code working.
> > Could someone confirm this change won't be reverted in the future
> releases?
> > Best regards,
> > Tamas
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100304/8002795f/attachment.html
