[mapserver-dev] Using mapserver with non-projected raster files
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Mar 8 11:55:58 EST 2010
Hi all,
I've been using MapServer for a long time to display raw raster files
without projection information, to get control points for
georeferencing. Up to MS 4.10.5, this was no problem, but with 5.6.0
mapserv hangs: no error, the application just doesn't finish. Is this a
bug or is MapServer meant to work with projected files only nowadays? If
so, there should be an error message, but I would prefer the old behavior
Jan
