[mapserver-dev] Ready for 5.6.2?
Tue Mar 16 19:06:28 EDT 2010
Tamas Szekeres wrote:
> Hi All,
> #3356 looks good, however I have a couple of strange issues with regards
> to the single-pass query to the OGR data sources.
> Unfortunately I haven't had enough time to look into the details and
> identify the location, however it seems like the followings may happen:
> 1. Performing a querybyRect, resultsGetShape may select wrong features.
> 2. resultsGetShape may retrieve different features when panning the view
> within the same selection. (A persistent mapObj reference is required
> between the pan operations to test this)
> 3. GetShape doesn't work anymore (ie. the former 2 pass approach). It
> retrieves null shapes with no items.
> 4. Moving the selected shapes outside of the visible region MapServer
> triggers an error (failed to draw layer)
> Could someone confirm whether the query is working with the OGR data
> sources at all, using the current stable branch?
Tamas,
I'll look into this and see if I see any issues.
Best regards,
