[mapserver-dev] Re: 5.6.1 is crashing down be looping the labels
teeschke daniel.teske at web.de
Wed Mar 17 14:36:59 EDT 2010
hi Alan.
5.4.2 works fine The "Debug 5"-Report is not so detailed like the 5.6.1 one:
[Wed Mar 17 19:30:06 2010].793000 CGI Request 1 on process 2200
[Wed Mar 17 19:30:06 2010].793000 msOracleSpatialLayerOpen called with:
GEOMETRIE FROM MY_LINE_TABLE using unique ID srid 82015
[Wed Mar 17 19:30:06 2010].902000 msOracleSpatialLayerOpen. Shared
connection not available. Creating one.
msConnPoolRegister(labels,MY_CONNECTION,021DA030)
[Wed Mar 17 19:30:06 2010].918000 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Mar 17 19:30:06 2010].918000 msOracleSpatialLayerInitItemInfo was
called.
[Wed Mar 17 19:30:06 2010].918000 msOracleSpatialLayerWhichShapes was
called.
[Wed Mar 17 19:30:06 2010].918000 msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT ID, NAME, GEOMETRIE FROM MY_LINE_TABLE
WHERE SDO_FILTER( GEOMETRIE, MDSYS.SDO_GEOMETRY(2003, 82015,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(2434248.92,5406417.08,2765508.08,5670471.92)
),'querytype=window') = 'TRUE'
[Wed Mar 17 19:30:10 2010].452000 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Mar 17 19:30:10 2010].452000 msOracleSpatialLayerClose was called.
Layer name: labels. Layer connection: MY_CONNECTION
[Wed Mar 17 19:30:10 2010].452000 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Wed Mar 17 19:30:10 2010].452000 msOracleSpatialLayerClose. Cleaning Oracle
Cache.
[Wed Mar 17 19:30:10 2010].452000 msOracleSpatialLayerClose. Release the
Oracle Pool.
msConnPoolRelease(labels,MY_CONNECTION,021DA030)
[Wed Mar 17 19:30:10 2010].452000 msConnPoolClose(MY_CONNECTION,021DA030)
[Wed Mar 17 19:30:10 2010].452000 msDrawMap(): Layer 87 (labels), 3.659s
[Wed Mar 17 19:30:11 2010].843000 msDrawMap(): Drawing Label Cache, 1.391s
[Wed Mar 17 19:30:11 2010].843000 msDrawMap() total time: 5.050s
[Wed Mar 17 19:30:11 2010].921000 msSaveImage() total time: 0.078s
[Wed Mar 17 19:30:11 2010].921000 mapserv request processing time (msLoadMap
not incl.): 5.128s
[Wed Mar 17 19:30:11 2010].921000 msFreeMap(): freeing map at 0190B3D8.
[Wed Mar 17 19:30:11 2010].921000 msOracleSpatialLayerClose was called.
[Wed Mar 17 19:30:11 2010].921000 freeLayer(): freeing layer at 01E15DE0.
[Wed Mar 17 19:30:11 2010].921000 freeLayer(): freeing layer at 01EF3550.
[Wed Mar 17 19:30:11 2010].921000 freeLayer(): freeing layer at 01EF5D70.
[Wed Mar 17 19:30:11 2010].921000 freeLayer(): freeing layer at 01F3E948.
[Wed Mar 17 19:30:11 2010].921000 freeLayer(): freeing layer at 01F78FA0.
Maybe its important, this is the answer of mapserv -v (5.4.2):
MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
 OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICO
NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUP
PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
INPUT=OGR
 INPUT=GDAL INPUT=SHAPEFILE
Thanks and regards,
Daniel
View this message in context: http://n2.nabble.com/5-6-1-is-crashing-down-by-looping-the-labels-tp4743626p4752151.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
