[mapserver-dev] MapFile generator?
Tamas Szekeres szekerest at gmail.com
Wed Mar 17 17:05:48 EDT 2010
Mulone,
You're probably searching for an object model to access/generate the
mapfiles. In this regards you might want to use the Java MapScript API as
described at http://mapserver.org/mapscript/mapscript.html
Best regards,
Tamas
2010/3/17 Mulone <mulone at rome.com>
> Hi guys,
> I'm trying to set up a mapfile generator to generate a customised mapfile
> for different users in my system. Our system is written in Java/Groovy, so
> it would seem quite natural to me to set up a few classes modelling the
> mapfile content (classes, layers with all the options), and then manipulate
> these objects in my app (e.g. show/hide layers, change styles, scales,
> etc),
> and then call a simple "genMapfile()" and write everything to a temp file,
> then read by mapserver a few millisecs afterwards.
> This looks quite simple to do.
> My point is: do you know of any Java/Groovy generator of mapfiles? If not,
> do you think it could be interesting for you if I set up a google-code
> project on this idea? Do you think this is a sensible solution to my
> problem?
> Thanks for any comment!
> Mulone
> Mulone
> PhD student
> http://n2.nabble.com/MapFile-generator-tp4752655p4752655.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100317/89aa28b5/attachment-0001.html
