[mapserver-dev] Re: MapFile generator?
Mulone mulone at rome.com
Fri Mar 19 09:02:45 EDT 2010
In relation to mapscript, would it be possible/interesting to isolate the
classes dealing with the mapfile leaving all the trick bindings out?
I mean, in the end what a lot of developers need is a simple tree to handle
and generate valid mapfiles, without messing with other things. I'm finding
the java binding quite tricky to integrate because I'm working on a
framework (Grails) and I don't know how to make the DLL work in my set up.
Any ideas in this regard?
Cheers,
Mulone
Mulone
PhD student
View this message in context: http://n2.nabble.com/MapFile-generator-tp4752655p4762709.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
