[mapserver-dev] Re: MapFile generator?
Tamas Szekeres szekerest at gmail.com
Sat Mar 20 14:51:58 EDT 2010
The MapScript Java bindings is used on the server side primarily, and it
would not be so straightforward to utilize that in a browser on the client
side. However you could implement a Java standalone application according to
your requirements below. In this case, you could easily install all the
required dll-s to the required locations (depending on your platform).
Best regards,
Tamas
2010/3/20 Mulone <mulone at rome.com>
> Thanks for your reply.
> My point is that we need a structure to load, manipulate and generate
> mapfiles similar to an XML/JSON parser.
> Something like:
> mapfile = new Mapfile( path );
> mapfile.getLayer('buildings').setColor( newcolor );
> // change structures
> mapfile.write( new path );
> Probably we don't need to call functions on the server, so I was wondering
> if it is possible to extract a smaller library to do this.
> We could easily write it ourselves, but it would be a bit of a waste of
> time, given that all that logic is already written in mapscript.
> Cheers
> Mulone
> PhD student
> http://n2.nabble.com/MapFile-generator-tp4752655p4769517.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100320/228fb3cb/attachment.html
