[mapserver-dev] Re: strange behavior when size != gif size (UMN 5.4.2)
joncoign jncoign at Knology.net
Wed Mar 24 11:14:58 EDT 2010
I'm seeing the same behavior using the
OUTPUTFORMAT
    NAME "png"
    MIMETYPE "image/png"
    DRIVER "GD/PNG"
    EXTENSION "png"
    IMAGEMODE RGBA
    TRANSPARENT TRUE
END
Using a customized build of 5.6 (customizations are not in the rendering
code, they are limited to pre-processing the map file before the CONNECTION
to the DB is executed).
Icons literally go completely white when scaling them down to 25% or less of
there original size.
View this message in context: http://n2.nabble.com/strange-behavior-when-size-gif-size-UMN-5-4-2-tp3479658p4791602.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
