[mapserver-dev] Proposing some homepage changes...
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Thu May 6 17:44:30 EDT 2010
Hi Jeff: I think it's a step in the right direction, visually anyway. Having to rely on the sphinx generated TOC on the homepage is a serious
drag though. Having to run users through a local link is kinda silly. I'm wondering if we could craft our own TOC just like we do when
embedding the OSGeo and FOSS4G html? We might be able to hide the sphinx generated TOC with local styles just for that page.
Thanks for the first cut!
Steve
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna [jmckenna at gatewaygeomatics.com]
Sent: Tuesday, May 04, 2010 12:20 PM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Proposing some homepage changes...
Hi Steve,
I fully agree with you.
I made some minor changes so that the announcement sections no longer
appear in the TOC: http://www.mapserver.org/
I also made an attempt to clean up the left sidebar nav, with the
sections that you suggested, through our Sphinx layout template:
http://www.mapserver.org/trunk/en/index.html
Impressions/comments?
Personally, I like it better.  What I don't like is the "Table of
Contents" section that still remains on that index page - oh I tried to
remove it, searching the Sphinx Google group, trying many different
ways, but in the end I failed to remove it.  It only appears on some
pages though.
It's a start?
-jeff
Lime, Steve D (DNR) wrote:
> Hi all: I'd like to propose some changes to the mapserver.org homepage. Wondering how feasible they'll be via Sphinx:
>   - Breadcrumb. Really should start at "Home" and then go from there, e.g.:
>     Home >> Documentation >> MapScript  or
>     Home >> FAQ
>     Home >> Develelopment >> RFCs
>   - TOC on the homepage shouldn't be announcements but rather something like:
>   Community
>     Mailing Lists
>     IRC
>     Wiki
>   Development
>   Documentation
>     Introduction
>     FAQ
>     Mapfiles
>     MapScript
>   Downloads
>   Issue Tracker
>   - Announcements could continue below the fold on the main part of the homepage
> It's not user friendly as is. The shorter, more meaningful TOC would also help to pull the OSGEO and FOSS4G icons up the page. Thoughts?
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
