[mapserver-dev] How to create a new layer provider?
Stephen Woodbridge woodbri at swoodbridge.com
Sun May 23 20:33:47 EDT 2010
Hi all,
I have the possibility of creating a new layer provider for mapserver
and wanted to bounce some ideas around.
The use case:
Client has a search engine that has some simple spatial capabilities.
We would like to be able to connect mapserver to the search engine,
probably via an HTTP GET or POST request with a bounding box, and the
search engine would return a set of records that mapserver would draw.
The search engine would get an adapter written to format the data as
required, it can currently export data as JSON and XML. These could
probably be adapted to some existing standards, for example there is
probably not reason that we could not format data is WKT or WKB
cononical format like that used in postGIS.
The opportunity:
I am think that writing some custom interface is not much value to the
community, but if we wrote a generic mapserver consumer interface that
could be prototyped up in say PHP or python for the data provider, then
this might be more interesting and we could then also write the search
engine adapter to use that same interface.
Before I go too far down this line of thought:
1) are there other existing interfaces that this could easily be
implemented through, like OGR?
2) what would be a good example code that I should look at mimicing a
new layer provider?
3) I do not want this to get blown out of scope for what the client
needs, but I would be interested in ideas on how to make this more
generally useful to the community if we go forward with it.
4) I do not think we want to write a search engine adapter that
implements something as complex as a WFS service.
Assuming this goes forward, I will write an RFC up after I've done some
research and gotten some feedback.
Thoughts and ideas welcome,
   -Steve W
    http://imaptools.com/
