[mapserver-dev] Re: Decoupling Image creation from GD
thomas bonfort tbonfort at terriscope.fr
Tue Nov 2 02:50:07 EDT 2010
6.0
I should be merging with trunk in the coming days
On Tue, Nov 2, 2010 at 07:46, Paul Ramsey <pramsey at opengeo.org> wrote:
> Aha. Is the sandbox scheduled to land in 6.0 or 6.1?
> P
> On 2010-11-02, at 3:46 PM, thomas bonfort wrote:
>> Paul,
>> The code in my sandbox does that:
>> - GD library and structure is used only when working in a PC256 format.
>> - in RGB/RGBA, agg/cairo have their own memory structure, and there is
>> custom code in the trunk based on libpng/libjpeg to compress that
>> memory buffer.
>> regards,
>> thomas
>> On Tue, Nov 2, 2010 at 07:23, Paul Ramsey <pramsey at opengeo.org> wrote:
>>> Thomas,
>>> At the last sprint, I think I asked you if there were any plans to
>>> stop using GD to generate our final JPEG/PNG/etc images. When I look
>>> at the AGG driver for example, all the work is done against the GD
>>> image structure, which is finally passed to GD to create the image. I
>>> vaguely remember at the time you said there was a plan to change to a
>>> more standard RGBA structure and convert that to JPEG/PNG/etc
>>> directly. Is that plan still in action or is it a Vague Future Notion?
>>> Paul
