[mapserver-dev] MapServer documentation update
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Oct 4 17:41:03 EDT 2010
hi guys,
Daniel is right, it's probably me going on the server and manually
updating as root that causes problems.  Checking...
-jeff
On 10-10-04 5:36 PM, Daniel Morissette wrote:
> Tamas Szekeres wrote:
>> Hi
>> I've added some changes in the /docs directory in both the trunk and
>> branch-5-6 a few days ago, which doesn't appear to be updated on the
>> mapserver site automatically.
>> How is the doc update being done in the current approach?
> Tamas,
> The live server is updated using SVN branch-5-6 every hour or so. I see
> your commits in SVN branch-5-6 from Friday (r10566 and r10567) and they
> should be on the site by now but they are not.
> I suspect something must be broken with the automated update on the
> server. Alan or Jeff will have to check and fix it (Maybe a permission
> issue on the server? That's happened before after someone manually ran
> updates as root instead of as the cron job user).
