[mapserver-dev] RFC 62: Support Additional WFS GetFeature Output Formats
Fri Oct 8 17:25:10 EDT 2010
Stephen Woodbridge wrote:
> Regarding MULTI* support, I assume that you would have to support export
> features from all data sources, like postgis. It is common for the
> shp2pgsql loader to create MULTI objects by default. And while
> shapefiles are seem to be mostly NOT MULTI* by default I almost always
> find a random MULTI* in various files. I'm also wondering if the output
> of geometry processing function using GEOS that are built into mapserver
> will be able to be exported via this WFS writer? If so, then it would
> need to support all geometry types possible from that, which would
> include collections in addition to MULTI*.
I agree - I'll need to support multipoint, multiline and multipolygon
geometries.  Multipolygon will be a bit involved since in the
shapeObj there is no real way to distinguish between inner rings
of a polygon and outer rings of additional polygons implying I
need to produce a multipolygon.
> I guess this raises these questions in my mind:
> Do users need to be able to filter the output based on geometry type?
I don't see a compelling need for this, though there are already
mechanisms to do this for OGR inputs with a FILTER statement.
 > Do  we need to provide MULTI* dumpers to base type?
Do you mean a mechanism to split one multi feature into
several simple features?  I don't see this as critical.
I'll incorporate support for multigeometries in the RFC.
Best regards,
