[mapserver-dev] Proposal to add built-in OpenLayers map viewer
Bob Basques Bob.Basques at ci.stpaul.mn.us
Fri Sep 24 15:42:09 EDT 2010
All,
Well, that explains some of it, but now it's seeming like OpenLayers is a bit heavy for something like that, all mapserver would need to do something like pan/zoom would be something smaller than OL
Looking at the example, while is only loads a couple of lines in page, looking at it from the download in firebug, it's doing a few more things.  Is the real problem in keeping some list straight in the distro, and only one is desired?
bobb
>>> Daniel Morissette <dmorissette at mapgears.com> wrote:
Bob Basques wrote:
> So what would be the expected additional capabilities of using
> mode=openlayers over using mode=map?  (Especially with regard to only
> viewing a single layer, TBW, I see this MODE= option as primarily a way
> to compare more than one layer to others)  The many layers is what I'm
> interested in seeing as a test tool.  mode=map already builds a
> composite map.
At the moment, mode=map returns you a static image, you cannot zoom or
navigate it easily... this is the problem we want to solve.
The goal of mode=openlayers would simply be to provide an easy way to
preview a mapfile with a set of selected layers, zoom in and out and
navigate... more or less something like the following openlayers
example, but without any overlays, so even simpler:
http://openlayers.org/dev/examples/example.html
And if you "View Source" you'll see it's only a couple of lines to
generate... very lightweight, since most of the code comes from
openlayers.org.
Daniel Morissette
http://www.mapgears.com/
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100924/014830f4/attachment.html
