[mapserver-dev] Proposal to add built-in OpenLayers map viewer
Bob Basques Bob.Basques at ci.stpaul.mn.us
Mon Sep 27 14:32:46 EDT 2010
Ok,  Now I'm lost,
What in MapServer 5.6.x does NOT allow the integration of providing a URL based viewer (without further coding??) already.
All I'm suggesting is using a flexible approach, you seem bent on making the mode=openlayers option the final thing (whch would take aonly a few lines in the code to utilize a call to a TEMPLATE (that has the openlayers calls in it)  just as easily as embedding the Openlayers calls in the code.  Did I miss something more inportant somewhere?
>>> Daniel Morissette <dmorissette at mapgears.com> wrote:
Bob Basques wrote:
> I don't see the TEMPLATE route as being any more (or less) of a problem
> in adding as a method to achieve the desired results, and it leaves a
> measure of flexibility behind as well. I mean if you need a MAPFILE
> anyway, what's the difference in adding a TEMPLATE for use as well.
I'm sorry but I don't get it... what is "the template route"... and what
does it allow you to do that you cannot already do today with MapServer
Daniel Morissette
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100927/55f400df/attachment-0001.html
