[mapserver-dev] Re: Motion: Adopt MS RFC-61 - Enhance MapServer Feature Style Support
Tamas Szekeres szekerest at gmail.com
Thu Sep 30 15:04:54 EDT 2010
Alan,
Thank you for sorting this out, it looks fine for me.
Best regards,
Tamas
2010/9/30 Alan Boudreault <aboudreault at mapgears.com>
>  Ok, I've fixed the mapserver site multilanguage functionnallity: the
> script that was copying untranslated files in the different language
> directories had been lost when the old server died. Now the build scripts
> are in svn.
> I've modified the build_docs script to use the RFCs from trunk when
> building. So, when you write a rfc, you only have to commit it in trunk and
> add its name in the rfc/index.txt file. Note that you can also see a preview
> of the development version of the documentation at this url:
> http://mapserver.org/trunk/
> regards,
> Alan
> On September 30, 2010 08:33:55 am Daniel Morissette wrote:
> > Alan Boudreault wrote:
> > > To fix this simply, one thing that we could do is to copy all the RFCs
> > > (for all languages) from trunk in the 5-6 branch during the
> > > documentation update. That way, all rfcs would be up-to-date on the
> site
> > > web. At the same time, I can set mapserver.org/trunk to have a preview
> > > of the current trunk doc.
> > BTW, just to clarify, what Alan means here is to have the hourly update
> > script on mapserver.org copy the RFC files from the trunk directory to
> > branch-5.6 directory after the svn update... that would happen locally
> > on the mapserver.org server itself without affecting anything in the SVN
> > repository or changing anything to the way devs/docs contributors work
> > on docs locally on their systems.
> > Makes sense?
> > Daniel
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100930/f86041e4/attachment.html
