[mapserver-dev] RFC 67 - Enable/Disable Layers in OGC Web Services
Daniel Morissette
dmorissette at mapgears.com
Fri Apr 8 16:58:28 EDT 2011
On 11-03-25 02:02 PM, Alan Boudreault wrote:
> Devs,
> Currently, the DUMP keyword has to be set to allow a few OGC requests. ie. WFS
> GetFeatureInfo. Since we implemented a way to Enable/Disable OGC web services,
> what about removing that mandatory setting? At the same time, I would also
> remove the TEMPLATE dependency to see if a layer is queryable or not. I
> suppose that to see if a layer is queryable, we would have to check the
> GetFeature/GetFeatureInfo in the *_enable_request?
I'd say we should try to drop the DUMP keyword before the next beta if
we can and if other devs don't expect a problem with that (maybe write a
motion and discuss it, like we did for the removal of symbol keywords a
few days ago). I'm thinking especially Assefa and Steve may have an
opinion on this.
With respect to the template vs query thing, I don't think we should
touch it.
Daniel
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
